called to above indesit washer dryer not drying well . there seems no method of condensing steam , it only has a double valve and no hose to condenser housing , is this normal ? please advise. Geoff 1312
Have come across some double valve W/D versions. Not sure if they can be tied down to a single CC, may be related to serial number? They use a standard unrestricted W/M valve, taking short bursts of water through the dispenser (often causing a thumping noise from the fill pipe)
Would be interesting to see a service manual if anyone can find one
Hi Murv this is exactly the machine i went to . Thought Indesit had made a cock up and forgot some bits. How on earth do they expect that to condense the steam ? Not much I can do as everything else is fine, not a very old machine . Elderly cutomer is gonna try it again fingers crossed . Thanks for your reply Geoff.
This model looks like an experiment to see how many different parts in the factory can be turned into a wash dryer. I have come across 14 commercial codes some of which have both double and triple valves. Other differences include just about everything – plastic drum, weights, hoses, door seal, condenser, dryer assy, module, and plenty of software versions to control it all.
