indesit iwdd7143 f13 thermostat test?
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum indesit iwdd7143 f13 thermostat test?
  • #93655
    pod495
    We’re getting F 13 on our iwdd7143 washer dryer.
    Various internets say it’s likley the thermostat (thermistor?)
    What results should i expect with a multimeter please? (Before i start dismantling the machine or buying a new part).
    Cheers
    #455140
    Re: indesit iwdd7143 f13 thermostat test?
    according to the machines manual F13 is as follows
    NTC dryer sensor open / short circuiting. this is the electronic thermostat mounted in the dryer section at the top of the machine. it could be a loose connection, broken wire or component failure (expected resistance 20,000 ohms at 20 degrees C)
    Fan Motor jammed.
    Condenser or blower clogged
    pod495
    Thanks.
    Now dismantled (1 of the torx was particularly awkward but i got there)
    I’m reading 19.87 ish on the 20k setting on my meter which suggests the thermostat is ok, right?
    Can’t see any worn wires.
    There is a lot of lint on the fan so I’ll give that a clean.
    #455142
    the condenser feeds into the fan chamber. look down with a torch see if you can see a build up of fluff there too
    dave
    #455143
    pod495
    Thanks.
    I thought if solved it. It seemed to run alright for a while after cleaning the fan.
    But now fully rebuilt and it’s done an f13 again and now an f15 too! And makes a whiny noise that sounds like the fan.
    I’ll try to have another word with it when i get time.
    Can the fan/motor be tested while dismantled do you think?
    And is there a proper way in to clean the condenser area?
    #455144
    any way you can. old wire coat hanger can be useful. loop on one end ( protect your eyes) and a right angled hook on the other to pull lumps out
