Indesit IWDD7143 – h20 error
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit IWDD7143 – h20 error
  • #96724
    asp11
    This machine has just started showing the H20 error towards the end of the wash…. inlet pipe, drainage spout, pump, pressure system, filter, sump hose are all fine – it fails around 10mins from the end and it just stops, mainly with water inside and just sits there with no sounds or clicks…… stop it and put it on empty or spin and its perfect.
    it has started to take some time to start on any program so I’m thinking pcb issue….. any ideas please?
    #464585
    twicknix
    What did you do resolve in the end? As I have similar issue here, beeping during rinsing but water supply, drainage are clear. Maybe pressure switch playing up?
    #464586
    could be pressure switch have you checked pressure chamber ?
