hi we have an Indesit IWDD7143 Washer Dryer that has been tripping the rcd As soon as you plug it in. I think that I’ve narrowed it down to a pcb fault but would like to know if there is anything else i can try just to make sure.
what i have done is,
changed the fuse in the plug & Changed the plug.
tested each of the components doing this:
1 reset rcd
2 disconnect all wires from 1 component
3 plug washing machine in
4 if rcd trips unplug washing machine
5 reconnect component
6 Repeat
and the only time the rcd did not trip was when i unplugged the PCB.
would i be right in thinking that the PCB is what’s causing the Problem?
Thanks For Any help of assistance 🙂
