Indesit IWDE 126 – 4 Green Lights + Red Light –
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit IWDE 126 – 4 Green Lights + Red Light –
  • #91199
    pmhunnisett
    I have an Indesit IWDE 126; the washer dryer will successfully go through the cleanning cycle however once it comes to drain it cuts out after around 15 seconds.
    At this stage all 4 green lights flash off set to the Red light.
    So all 4 green lights Flash; Red off
    All 4 green lights off, Red Flashes
    I have changed both the Control board and fitted a new pump; all hoses are clean and secure.
    Any suggestions im going mad here!
    Paul
    #447389
    Re: Indesit IWDE 126 – 4 Green Lights + Red Light –
    the dryer thermistor failure can cause the pump to only run for 5 to 10 secs or so
    look for broken wires going to it
    https://shop.ukwhitegoods.co.uk/c002902 … thermistor
    one of those faults that don’t make sense but if it is faulty it will cause it
    pmhunnisett
    Hi Dave
    Thanks for the reply; where is that thermistor situated, i have the machine apart cant see it
    Paul
    #447391
    on the top in the tumble dryer section front right. think its 2 thin blue wires going to it but the go through a holder first and it can break at this point
