Hi Folks. Been to this one this morning, Indesit washer dryer.Complaining not drying properly. Everything is working fine, heaters,fan, cold water feed and the condenser looks reasonably clean.They also use a standard vented dryer and from the way they are talking they are comparing the performance of the two.
It is a kind of care home and didn’t want to attempt to remove condenser without a little more info. The bottom end looks as though it is held on with a single 8mm nut which must tighten against a flange or ‘o’ ring of some kind.
Any info from the Indesit guys greatly appreciated. 😀
