Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit IWDE12 flashing lights and will do nothing
- This topic has 7 replies, 4 voices, and was last updated 10 years, 5 months ago by
k9pup.
October 12, 2015 at 2:46 pm #86357
k9pup
ParticipantI have a indesit IWDE12 washer dryer that has started to flash all the lights on it and won’t allow any functions.
Have checked the filter on the front and there was nothing in there.
Now all the function lights on the top row flash constantly but just the 9h light (bottom of 4 lights) in the column going down the panel.Anyone help with what it’s trying to tell me?
October 12, 2015 at 3:52 pm #430872iadom
ModeratorRe: Indesit IWDE12 flashing lights and will do nothing
If you mean the bottom light in the right hand vertical column (door lock0 light is on steady then it is trying to tell you that it is very poorly indeed.
Fault code F01.
Main PCB, Triac on board damaged or components.Feedback fault.It could just be broken wiring at the motor plug if you are very lucky.
October 12, 2015 at 5:58 pm #430873k9pup
ParticipantRe: Indesit IWDE12 flashing lights and will do nothing
Thanks!
Just to be clear I took a picture and highlighted the offending lights but all of them are flashing, none are solid.
October 12, 2015 at 7:17 pm #430874iadom
That doesn’t look like recognised error code TBH, sadly I don’t have access to that exact models error codes but six lights flashing is not an error code on any Indesit machine AFAIK.
October 13, 2015 at 6:31 pm #430875k9pup
Thanks for your help.
Now I know it’s not something I can deal with myself.October 14, 2015 at 8:31 am #4308761totalshambles
If this is where all said lights flash really fast- 4x a second approx then isn`t this the printed circuit board fault bottom rear right hand side? From memory there`s a capacitor that fails, visually the silver base swells up in to a dome..this is what you`d be looking for in comparison to the several other cylindrical shaped caps on the board which`ll all have flat base. A cap is less than £1 from Maplins and so long as it is close to the original cap value it shouldn`t matter. Take note of the `-`sign as marked on the cap`s side so you solder the new one the right way round-this does matter. Power off/ unplugged of course, wait 15 mins to be on the safe side, then remove the board from the machine and mark and also draw on paper where the board wires go to save any confusion before taking the wires off.
October 14, 2015 at 10:03 am #430877iadom
From the two pictures shown this is not the classic capacitor failure.
August 26, 2017 at 12:14 pm #430878Cathalm
Hi k9pup,
I have same problem with my washer. Did you get your machine fixed? If so how and at what cost? -
