I’ve got an Indesit IWDE12 washing machine. It has recently stopped draining; if it’s told to do a wash cycle, it manages the initial wash fine, but instead of draining makes a low humming sound, and the power light and two others (the lights above the iron and 1200/600 buttons) start flashing rapidly.
From what I’ve been able to find it looks like the problem is probably that the drain pump is obstructed, and I should clear it out. So in the manual it says I should do this by unscrewing the pre-chamber lid on the front.
I’m able to unscrew this lid about a third of a revolution, and water drains out there; that’s how I was able to empty it. However, I’m unable to remove the lid itself. Does anyone know if there’s some trick to this? It feels loose when unscrewed, and it doesn’t seem like it’s going to unscrew any further, but it won’t come out.
Rob
