Indesit IWDE12 not working (LED (2h) constantly lit)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit IWDE12 not working (LED (2h) constantly lit)
  • #101434
    DesperateJohn
    Hi, after pressing the Start/Reset button my Indesit washer-dryer IWDE 12 has all the LEDs off except the top LED to the left (labeled 2h). This LED stays constantly on. Is this an error code? What could be the reason? (I tried to unplug and waited for several minutes; I also tried to cancel the program by long-pressing the Start/Reset – nothing helped so far).
    #484731
    do not have the correct fault listing for this machine but a suspect its fault 8
    remove plug then
    find and disconnect wires to the wash heater. make sure they cant touch anything and switch on and see what happens
    DesperateJohn
    Hi Dave,
    Sorry for my late reply.
    The image of the front panel is here: https://files.fm/u/xm3yagh6b
    I believe this is not an error code.
    I first measured the wash heater, then did a few other measurements of the accessible parts… everything seemed to be ok.
    I have finally solved the problem by replacing the brushes of the motor.
    Thank you for your time.
    #484733
    brushes make sense now i can see the panel
    a lot of machines wont start if brushes are not making contact
