Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › indesit IWDE126 fault
- This topic has 12 replies, 3 voices, and was last updated 12 years ago by
sm17hy.
March 19, 2014 at 10:19 pm #80015
sm17hy
Participanthi
I have a indesit IWDE126 washer/dryer.
It is aprox 2years old.
Recently the machine dash has started to flash.
I’ve turned it off and on.
Unplugged overnight.
And manually drained and removed debris.
The machine will occasionally work, although the door never opens at the end of a program.
Normally after a few minutes of the cycle finishing the solid red lock light will begin to flash to indicate the door can be opened.
The light now always stays solid.
Also the machine will sometimes stop the cycle and the door lock light will flash with the reduce spin speed light.
Any ideas to what this could be?March 19, 2014 at 11:42 pm #411362iadom
ModeratorRe: indesit IWDE126 fault
That error code is F01, motor triac ( main pcb faulty) 😥
March 20, 2014 at 6:59 am #411363sm17hy
ParticipantRe: indesit IWDE126 fault
is it normal for the machine to work on occasions?
I have since done one load and pushed on the door after cycle which made the light start to flash so I could open it.
The next wash was then fine.Regards
ChrisMarch 20, 2014 at 9:03 am #411364iadom
It’s an Indesit, nothing normal about them. :rolls:
It could be due to loose connections between the motor and the main pcb.
March 20, 2014 at 9:12 pm #411365sm17hy
haha very true. Would never buy one out of choice!
How would I go about checking this?
where is the pcb located and what does it look like?Regards
ChrisMarch 20, 2014 at 9:44 pm #411366iadom
The main pcb is down at the bottom rear. Not much you can do to check the pcb itself but you can make sure all the wiring connectors are in place and tight.
March 21, 2014 at 7:42 am #411367madangler1
Participantindesit IWDE126 fault
Have you checked the motor brushes ? Often f01 can just be brushes.
Its not always the pcb, in fact if its intermittent it normally is not it. Also check door lock as these have become increasingly problematic
, burnt wires or just faulty.March 22, 2014 at 10:34 am #411368sm17hy
Had a look at pcb and looks ok. Dry and all connections secure.
still managing to use it. Only problem is having to manually unlock it through the top every time.
And with it being integrated, it is now half stuck out.
I’m considering buying a new interlock?
Would this solve the end of cycle auto release or is this more just for the door to open function and not the electrical unlock?Cheers
March 22, 2014 at 10:49 am #411369iadom
The door interlock is not that expensive so possibly worth giving it a go.
March 22, 2014 at 11:38 am #411370sm17hy
might try that then.
I have just had dryer on and it’s stopped half way through.
Different lights are now flashing.
Delay timer – green light,
Easy iron – green light,
1200 – 600 spin – green light
All at the same speed.
And the door lock – red light which is flashing about twice the speed of the green onesMarch 22, 2014 at 12:19 pm #411371iadom
Always best to give the lights by number from top to bottom or left to right , ignoring the door lock light.
Or look HERE
March 22, 2014 at 2:03 pm #411372sm17hy
thanks says it’s heater fan fault.
But working fine again now!
I hate indesit!Been looking at a new one…
Any recommendations?http://m.samsung.com/uk/consumer/home-a … U-features
http://www.currys.co.uk/gbuk/household- … 6-pdt.html
http://www.currys.co.uk/gbuk/household- … 3-pdt.html
Although the lg might be out my price range :/
March 22, 2014 at 2:35 pm #411373iadom
Sorry, cannot recommend any model of washer dryer, possibly a Miele but no others.
The Hotpoint one is actually an Indesit. :rolls:
