Indesit IWDE126UK
  • #90374
    rickard
    This morning I went to look at this built in washer dryer, It will fill with water and wash fine but when it comes to pump out the pump will run and pump out for about 20 seconds, then it will stop and every light horizontal and vertical will flash, if you reset it on pump only it will do the same stop after 20 seconds. Could this be a control unit fault or just drain pump or something else throwing the board out. I did not have a pump to try in it and will have to order one to test it, any help please. Thanks. Andy
    #444579
    Re: Indesit IWDE126UK
    Could be related to This fault, can’t say I’ve done one on the later type pcb’s though??
    #444580
    rickard
    Thanks Jim
    I will give EMW a ring
    #444581
    johnnyj
    I would try plugging another thermistor in place of the dryer thermistor first.
    #444582
    DOH, keep forgetting it’s a washer dryer and just how many wierd faults the dryer ntc can throw up. 🙂
    #444583
    rickard
    Thanks Guys, I tried a new sensor and still the same so got a board from EMW and fine all working I could not see any damage to the board as you suggested though.
    Thanks for your help
