Indesit IWDE126(UK) – Water Valve
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit IWDE126(UK) – Water Valve
  • #93550
    Hollytree_Technical
    Hi all
    This machine is in a holiday caravan in one of the holiday parks here and has suffered with frost damage blowing the water valve apart, as the power was switched off to the machine at the time it looks like it is only the valve that needs replacing but I am not sure which is the correct valves for this machine.
    All of the parts lists that I can find for this machine say that it should be a 3 way valve C00111094 but the valve unit that is currently fitted on the machine is only a two way and looks more like C00111096, is this just a typo on Indesits part or should I be fitting the 3 way unit and leaving the 3rd valve disconnected?
    Industrial Code: 80624630296
    Jem
    #454765
    Re: Indesit IWDE126(UK) – Water Valve
    A complete shambles on Partfinder. 🙁
    The diagram shows a double valve and also a hot valve with the same position number (33) but the parts list and picture show a treble valve.
    However the wiring diagram is equally confusing and appears to show three valves?????
    All a bit muddled now but I think there was a mod a while back that did away with one of the valves, then again I could have just dreamt that. 🙂
    #454766
    kaibart
    Yes I’ve seen a double valve fitted on 1 of these as a treble will not fit as there is no pipe for the condenser I was wondering how the fluff is washed away
