on rinse programme, machine fills for about 1 min, tub rotates wash action, stops filling, wash action, starts filling with wash action but continues to fill. stops filling at about 3/4 way
up door then drains and H20 FLASHES. Machine continues to drain till empty
H20 means there is no water going in, or at least it thinks there isn’t, coupled with the overfilling, you should be looking at the pressure switch system, in particular looking for pinholes in the pressure hose or blockages in the pressure chamber.
Jim and all others,
found that the air tube had been rubbing against the
side panel. it was quite flat and there were holes in a length
of about 1.5 ins. replaced tube ..all is well.
i’ve had this tube damage on a couple of Indesits ages ago.
i think Indesit put a protective sleeve over the tube on some
late models.
another fix and a happy customer. 😀 😀 😆
