Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Indesit IWME126UK module
- This topic has 7 replies, 3 voices, and was last updated 11 years, 7 months ago by
Twoten.
September 11, 2014 at 7:18 pm #82204
Twoten
ParticipantCan someone give me the part number for a module to fit an Indesit IWME126UK / 211198688*80624659000.
I need one that is already programmed if available.
Thanks,
Keith.
September 11, 2014 at 8:35 pm #419128iadom
ModeratorRe: Indesit IWME126UK module
I would check out EMW and see if they will repair that pcb, if not it will need a new, five way connector and programming. :rolls:
September 11, 2014 at 9:09 pm #419129Twoten
ParticipantRe: Indesit IWME126UK module
Thanks iadom,
I originally checked with Connect who said I can use a C00270972 module and advised it was programmed!
I fitted this module and obviously didn’t work.
When fitted the machine returned a f09, eprom/setup error.
I will see if I can get a module from EMW. Do you know if this is likely to have damaged the fascia PCB?September 11, 2014 at 9:52 pm #419130iadom
If you still have that pcb then you could try the new connector harness mentioned above, don’t think it will have done any damage to the facia pcb.
September 12, 2014 at 8:47 am #419131Twoten
If the intervention is not done using 5 way harness the washing machine, after the first standby will never turn on again.
This is what is happening so I think the PCB is buggered.
I think my best bet will be gat a PCB from EMW and hope the other board is still OK, I think it should be.September 12, 2014 at 4:45 pm #419132johnnyj
Twoten wrote:Thanks iadom,
I will see if I can get a module from EMW. Do you know if this is likely to have damaged the fascia PCB?If it is not programmed it will throw up an F09 fault, i think connect are telling porkies here.
September 13, 2014 at 7:22 am #419133Twoten
johnnyj wrote:
If it is not programmed it will throw up an F09 fault, i think connect are telling porkies here.So should the C00270972 module be pre-programmed?
September 15, 2014 at 6:44 pm #419134johnnyj
Yes
