been to this washer all works but not very responsive to start button. doesn’t respond to starting or cancelling program. checked panel button makes contact ok . will this be thee small pcb or could the main unit cause these symptoms. cheers
Unlikely to be the main power card unless all the buttons are sluggish, in which case it could be either. Most likely dry joimts or a bad tact switch on the top pcb.
