The door on our Indesit IWME147 is refusing to open. The handle is not fully locked like it usually would be during a cycle – you can pull it all the way out – but when you do so the door will still not open.
The rest of the functionality seems to be working fine – you can run a cycle on it as normal and it seems to be draining fully etc. There are no lights on.
This problem occurred before, rather than after, a cycle. We closed the door then went to open it to add something else and it wouldn’t open. We tried running a cycle, hoping that would fix the problem, but it hasn’t.
Any ideas as to what the problem is / how we can fix this?
Thanks in advance.
