Indesit machine overfills with water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit machine overfills with water
  • #51683
    bobinCT
    I have Hirundo WDC 1026 also known as an Equator Washer Dryer EZ3612CEE and Indesit. Actually I have 3 that came out of an apartment building: 1 works, another has a split bellows seal that probably dooms it for cost of repairs and the third unit over-fills with water. I have been unable to find an electrical schematic and the parts list does not have any listing for an obvious water level sensor. When I turn the machine on, the water keeps flowing until I turn it off and drain it with gravity feed. Can you point me in the right direction?
    Thanks in advance.
    #308937
    Re: Indesit machine overfills with water
    Part listings, part numbers and spares available HERE.
    Water level control is by a diaphragm pressure switch. Remove lid and look for a small unit with a skinny hose running down from it. Switch should “click” when gently pressurised. Air hose may be detached or holed. Air bell at the bottom may be choked with goo – strip and clean job.
    Stay safe – power off.
    bobinCT
    Thank you! I found it. The claret beckons so I will dig into this tomorrow morning. Great forum and moderator. Cheers for now.
    #308939
    bobinCT
    Can you advise me on a model number cross reference to an Indesit machine? I think I will do better having a friend in the UK order parts for me than trying to buy them in the USA.
    #308940
    All you have to do to get the Indesit part numbers is put “C” in front of the Equator numbers. 😀
    bobinCT
    Penguin45,
    Thanks again. The hose on the pressure switch assembly was abraded and open to the atmosphere. Easily and inexpensively repaired with a length of vacuum hose and more careful placement of the foam bumpers. 😀
    #308942
    You guys’ll get the hang of front loaders in the end 😆 .
    Well done,
    bobinCT
    My Bosch dishwasher is next. It has been reported that it is not heating the water. I already read your advice to another post and imagine the basic design approach is similar. Like the governor said…. “I’ll be back” 😆
