Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit Moon
- This topic has 9 replies, 5 voices, and was last updated 14 years, 8 months ago by
bzz67.
August 11, 2011 at 3:48 pm #64451
bzz67
Participantbeen on an indesit moon today. model SIXL145UK S/N 709067672
Customer reported machine not draining, i removed a hair clip from pump. tried to test and the machine appears to be stuck on final part of wash, (most cycle lights illuminated) i pressed and held the on/off button to cancel the program but nothing happened, door wont lock, nothing works!! any ideas??November 7, 2011 at 4:24 pm #357120Firestarter
ParticipantIndesit Moon
Did you have any luck with that moon. I have exact same prob
November 7, 2011 at 4:44 pm #357121bzz67
ParticipantRe: Indesit Moon
to be honest i cant really remember but i am fairly sure i gave them a price for pcb repair by EMW but they did’nt go ahead with it.
November 7, 2011 at 4:53 pm #357122Martin
bzz67 wrote: i gave them a price for pcb repair
Was it………..???
November 14, 2011 at 11:19 pm #357123Firestarter
My customer is over the moon at only having to pay £120 for me to QER it. I’ll let you know if it works.
November 21, 2011 at 9:43 pm #357124Firestarter
QER reset it for £9.60! Result – charged customer nearly half of the £120 quote. Everyone happy
November 21, 2011 at 10:41 pm #357125iadom
ModeratorRe: Indesit Moon
I am sure I read somewhere that it is not a good idea to tip these machines back if full of water, something about upsetting the pressure switch and locking the machine out.
I darned if I can find the info ATM.
If I do locate it I will let you know, unless johnnyj, helo_75 or Bob Hope have the info to hand. 😉
November 22, 2011 at 6:38 am #357126timdowning
Is this it? :
if the sump was blocked you will have to reset the pressure switch, manually drain all water from the appliance via the drain hose by lowering it into a suitable receptacle. remove the pressure switch hose from the pressure switch and refit. Switch machine On.
Open door and fill drum with approximately 1 Litre of water. Close door. Set appliance to drain and start appliance; the pump will then drain the water out pressure switch and module now re-calibrated to zero.November 22, 2011 at 9:56 am #357127iadom
Good man, I knew it wasn’t my imagination. :tup:
November 22, 2011 at 12:16 pm #357128Firestarter
I did try resetting the pressure switch, but to no avail. Before I got there, my customer had relocated the machine and omitted removing the blue bung from the waste trap. He ran the machine 8 times, manually draining and restarting the moon each time. After that the moon would not reset with all but one of this progress LEDs lit. In desperation I confirmed the pump operated by blowing into the pressure switch to confirm the pump and door lock worked by putting it into anti flood mode.
I got the impression this machine could not cope with more that 8 no drain faults in a row, or did I use insufficient water, 1 pint, to reset?
