Re: Indesit Moon Model Sixl 145 UK won’t extract water
I checked the tub to pump hose and that was clear, I assumed that the pump to drain hose would not be blocked because anything big enough to block it would not get through the pump, I will remove the pump to drain hose and see if it’s blocked. If it isn’t have you any other ideas why it is not emptying?
