Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Indesit oven overheating
- This topic has 7 replies, 2 voices, and was last updated 10 years, 2 months ago by
boabie.
February 1, 2016 at 12:27 pm #87468
boabie
ParticipantHi
I’ve got an issue with my Indesit oven (indesit fm20kc ix gb) overheating. I thought it was a thermostat issue so I replaced it but the problem is still occurring. I’ve noticed that the light next to the temperature knob stays on even when it’s set to zero. At one point I banged the oven door (percussive maintenance!) and it started behaving normally i.e. the light would go on while it was heating up and go off when it reach the temperature. The thermostat was also tested with a multimeter outside the oven an appeared to be working normally.
What we have noticed is that the temperature knob and light seems to function normally and reliably when using the grill but not the oven. I’ve been thinking it might be something to do with the selector gubbins but I don’t know how much that will cost, how easy it is or if it will actually resolve the issue.
Can anyone point me in the right direction?
Robert
February 1, 2016 at 2:03 pm #434970Martin
ParticipantRe: Indesit oven overheating
boabie wrote:Can anyone point me in the right direction?
February 2, 2016 at 2:58 pm #434971boabie
Martin wrote:
boabie wrote:
Can anyone point me in the right direction?Any idea if it’ll help?
February 2, 2016 at 3:03 pm #434972Martin
boabie wrote:Any idea if it’ll help?
What will help? I don’t understand your question.
February 2, 2016 at 5:29 pm #434973boabie
Martin wrote:
boabie wrote:
Any idea if it’ll help?What will help? I don’t understand your question.
Whether changing the selector switch will help with my overheating problem. Do you think it’s worth a try or is there something else worth trying first?
February 2, 2016 at 7:01 pm #434974Martin
From the information you gave I too suspect the selector switch hence why I pointed it out as requested.
February 3, 2016 at 10:35 am #434975boabie
Martin wrote:From the information you gave I too suspect the selector switch hence why I pointed it out as requested.
Thanks for your help Martin. I’ll report back when I get it changed out.
February 9, 2016 at 10:22 pm #434976boabie
Ok so replacing the selector seems to have helped and I’m not currently seeing the issue any more. I’ll keep an eye on it and post back if there are any other issues. Thanks for your help.
