Hi All,
Just replaced the leaking drain pump in my IDL40 dishwasher, while checking everything else out I tested the overflow float switch, and found that it is normally open, making when the float rises due to flooding. This is the opposite to what I’ve always believed, ie normally made unless the float rises and the switch cuts off the power to the machine. I can’t find a wiring diagram anywhere so I’ve no way of checking it out, can anyone explain how this circut works?? Confused.com
