Indesit PAA642IX/IWE Constantly Sparking
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Indesit PAA642IX/IWE Constantly Sparking
  • #103719
    yucca
    Hello
    I have an Indesit PAA642IX/IWE gas hob and the electronic ignition keeps sparking every few seconds. All gas rings appear to be sparking. Even after the gas rings are lit, the sparking continues.
    Any idea what’s going on and does it need to be fixed by a gas engineer?
    #494321
    don
    Yes it will need to be repaired by a Gas safe registered engineer.
    From your description it sounds like the spark generator needs replacing, without seeing it I may be wrong.
    Don
    #494322
    It’s more likely a problem with one or more of the thermocouples Don, it’s got those on it.
    If it’s only when using one burner that’d indicate one thermocouple is faulty, but if it’s more than that it could be more of a pain to track what’s up with it.
    ok does it spark even if the rings are all off ?
    and yes as Don said. to fix anything on a hob the unit would have to be removed. since this would mean breaking a gas connection then any repair would have to be done by a gas safe engineer
