Indesit part identification?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Indesit part identification?
  • #73362
    gmb27
    Hi Guys,
    I’m having trouble trying to find the name of a seemingly obvious part I need to replace on my Indesit IDF125. Its the plastic part which secures the lower washer arm when you push it into it. I took the arm out and accidentally snapped one of the two small plastic clips that secures the arm. It looks like the piece needs a hex key to remove.
    Does anybody have an idea of the bit I’m talking about?
    Thanks in advance
    #387239
    andyjawa
    Re: Indesit part identification?
    Part is called a lower wash arm bush Indesit part number c00256577 and it should screw out of the sump anti clockwise as per a normal thread from memory. The lower wash blade is part number c00256578 if you want to know this too. Pretty sure this is what your after.”It looks like the piece needs a hex key to remove”-not as far as I remember, it just unscrews from the sump but if you mean it has a moulded hexangonal for a spanner for tightening you could be right-don`t have a picture to look at so unsure!
    #387240
    You’ve been a member over 5 years now andyjawa and your sudden ‘reamurgence’ prompts me to ask :- Have you not applied for Trade membership?
