indesit part number
Home Forums Public Support Forums Spare Parts Help indesit part number
Viewing 15 posts - 1 through 15 (of 15 total)
  • #29687
    kreid
    indesit wd 10, leaking water from a corrugated wee hose at the back(not the waste water pipe, this one’s inside the main housing)…don’t know what it is called?
    #224112
    Re: indesit part number
    Is the hose black rubber or grey plastic, what components does the hose appear to be attached to, is it at the top or the bottom, left hand side or right. I could go on but you really need to enlighten us a little to allow us to help. 😉 😀
    kreid
    will go get a look at the part bexactly tomorrow, in daylight! Thanks and i will get back on the 1.
    #224114
    kreid
    Went out today to the flat and checked things. The hose is located at the bottom of the machine.There are 2.The one that is leaking is the narrower of the 2 concertina type hoses.It attaches to the drum with a large circlip, it is wide mouthed at this end. At the lower end it is the same width as in the middle and attached by a smaller circlip to what looks like a little pump. The hose is rubber, soft and very pliable. And black.
    #224115
    C00064531 should be what you want – spares@ukwhitegoods.co.uk will get one for you quickly.
    kreid
    thanks very much, will get onto the now.Keith.
    #224117
    kreid
    did as you suggested, but got this email back….
    “If this is the hose from the bottom of the drum to the pump/filter, there
    are two types, could you advise the serial number please.”
    How do i sort this, is the serial No printed on the hose (haven’t taken it off yet).
    #224118
    Hi kreid,
    No, Dave means the serial number of the actual machine off the rating plate.
    They often change parts on production and the only way to know what one is right is to have the date code information which we can extract from the serial number of the machine. :rolls:
    HTH
    kreid
    doh!Should have thought on that. Thanks, Keith.
    #224120
    kreid
    there are several numbers, on the back and on top of the drum housing,…which 1 is it ?
    #224121
    helo_75
    the one inside the door……..
    #224122
    kreid
    starting with S/N…? If so yeeha.
    #224123
    kreid
    sent off details as advised, but the wrong part has attived. They have sent the wider of the 2 hoses, not the narrow one.This (wrong) hose also has two “mouths” at one end. Either I got the wrong number here or they have sent the wrong part by error…..first i have to establish that i do, or don’t have the right part number.
    #224124
    Dave_Conway
    The part number above and what you have received is the drum to filter (sump) hose. You need the detergent recovery hose.
    We have sent the right part it’s just confusion in the description. There is also a picture of the part on the online shop to try and stop any confusion 😉
    http://shop.ukwhitegoods.co.uk/product_ … ts_id=1676
    I’ll reply to the email also sent shortly regarding return/replacement. 🙂
    #224125
    gordman
    Thank you for the info, I am whit a similar problem…
