Indesit possible F17 fault
  • #26650
    Customer just phoned, neon 4 flashing, supposed to be door lock fault but he says door is locking, I may be imagining it but I seem to remember someone having this fault and it was the fill valve that was OC.
    Was it just a dream ( nightmare more likely ) or can a duff fill valve throw up F17?
    helo_75
    Re: Indesit possible F17 fault
    not sure if f17 is a fault
    anyway.. if the doors locking and the machine aint starting, its usually the brushes to be fair, but ive had faulty valves, even the board burning on the valve connection
    so, as ever with indesit… could be just about anything 😆
    #210937
    Neon four flashing on its own apparently, says it starts to fill for a couple of seconds then goes dead with neon flashing. Although it also could be a triac fault according to the error codes. 😥
    Only 14 months old, will take a look on Wednesday.
    helo_75
    take a proper machine with you, and sell em summink decent
    #210939
    hotpnt
    which model was it?
    #210940
    hotpnt
    led 4 flashing is a triac failure, will fill for few seconds then do system check, pick up the triac fault and flash no4, sorry, looks like another great module bit the dust
    #210941
    Not actually been out ot it yet. Will let you know the outcome. 😥
