My indesit condenser dryer when turned on only makes a sucking noise like pump trying to get water and does this for as long as it’s on it dosent try to spin or dry anyone know what could be broken thanks
try
unplug and take the lid off
make sure there are no children around. push the drum to make sure it can turn. dont push it too fast. If yes then plug it in and select a programme. Then push start and at the same time give the drum a gentle push. if it continues to turn leave it for 10 secs or so then open door and see if it heats
take out the water draw and pour a cup of water (no more) slowly in the tray under the draw. then when you turn on you should see the water pumped into the draw
