Indesit RI 860 C All radiants lacking heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit RI 860 C All radiants lacking heat
  • #100491
    Geoff1312
    Hi Guys,
    Called to the above ceramic hob. It seems that more than one radiant is lacking heat i.e. won’t make the fat in a frying pan hot enough.
    Seems strange to me that more than one should go down at the same time.
    When you first put it on the whole radiant glows, after a while the central element goes off ?
    Any help would be gratefully appreciated.
    Indesit RI 860 C i.c. 61042750000 S/n 902025009867
    869991042750
    Geoff 1312
    #480844
    as far as i can see this is simple controls
    my best guess at this is wrong pans
    if the pan cannot soak up the heat the ring overheat stat shuts it down
    Geoff1312
    thanks Dave, the whole ring doesn’t shut down just the centre coils, but i will check and see if they’ve recently got new pans . thanks again.
    Geoff
    #480846
    circuit seems to show 3 elements in each ring
