I ordered a new set of door hinges for this oven..when sliding the lower hinge into the slot, the locking clip would go flat enough to close the door !!.. ..I cant see why..as they are the correct part also checked with original ones exactly the same…anyone had this problem .
thats what I have but confused as they differently don’t fit..the pushdown lugs are hitting the frame of body so unable to force them down..may have to grind them down to fit..no other answer…thanks for you help..John
