Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Indesit single oven intermittent fault
- This topic has 8 replies, 3 voices, and was last updated 15 years, 6 months ago by
marley102.
September 28, 2010 at 6:52 pm #57568
marley102
ParticipantI wonder if anyone could give me some advice. Indesit built -in single oven, Model no. FM 20K.C IX GB Serial no.307170504 /
Cod. 03289140000I have had this oven for the past 4yrs and has worked fine, lately it has been tripping the main electric mcb in consumer unit when i switch the oven on. This is an intermittent fault, doesn’t always happen. Any ideas on remedies or fault finding appreciated
September 28, 2010 at 7:51 pm #331583gandh1
ParticipantRe: Indesit single oven intermittent fault
is it on the 13a ringmain or dedicated 45amp hardwire circuit
September 28, 2010 at 8:25 pm #331584marley102
Sorry forgot to add that it is on 13a ring main and has been since being installed 4yrs ago. The this ring main is dedicated to the Kitchen only and only has the oven, built-in fridge and freezer on the same ring. thank you in advance for your help.
NathanSeptember 28, 2010 at 8:27 pm #331585bazza500
When you say the “main MCB” what exactly goes off?
September 28, 2010 at 8:34 pm #331586marley102
Hi bazza500, the main rcd on the board trips off when i turn the oven on.
September 28, 2010 at 8:43 pm #331587bazza500
If the RCD is tripping then there is an earth fault in the oven. 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time this is caused by the element but without putting an insulation tester on the appliance you could not be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure.
September 28, 2010 at 9:16 pm #331588marley102
Ok thanks for you help bazza500. Will try and get someone to test that for me. Any advice or pitfalls i should watch out for during changing the element, is it a straight forward installation?
September 28, 2010 at 9:19 pm #331589bazza500
Fairly simple task, just remember power off first.
October 3, 2010 at 12:26 pm #331590gandh1
does it work ok on grill ?
only reason i ask is these are fan assisted – not a true fan oven, so it doesnt have a fan oven element, just a dual grill/oven top element. and cos the grill simultaneously uses both circuits on the top element, if it grills ok, then the base element has gone. hence the “intermittance”
