I need some clarification on an error code please for an Indesit DSIE2B10UK.
The start light is blinking continuously and the 1st and 3rd program lights are illuminated (there are 5 program lights). Is this a pressure switch fault?
The machine fills for about a minute and then it drains out and the drain pump continuously runs.
1, 3 is a pressure switch fault
but
what worries me is the start light. A lot of codes use start light as 4th lamp . that would make it 1,3,4 which is dead board
all you can do is check pressure sw for blockages. also check wires at bottom of door just in case
Its usually only the steady lights that are used for the error code so in this case I suspect that it will be a gunged up pressure chamber (it seems to be becoming far more common for some reason).
