Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit TD Model IS60V (vented dryer)
- This topic has 12 replies, 8 voices, and was last updated 18 years ago by
M1.
March 11, 2008 at 7:54 pm #35212
M1
ParticipantI have got two of these with the same problem after a couple of mins drum rubs making a terrible niose, stripped down tryed packing with washers etc. but same problem (can’t seem to find were the drum rubs)
I have tried playing with the door & it seems that the door gets pulled in to tight by the door switch and buckles the frame of the machine, I can make it quieter by packing out the door.Any one had simillar problems or am I going MAD !!!
March 11, 2008 at 7:58 pm #245536lerch
ParticipantRe: Indesit TD Model IS60V (vented dryer)
Sounds like you a shaft kit fitted. Part number hotp1703080. 😀
March 11, 2008 at 9:27 pm #245537Simon46
I just moved one and had to go back for it scraping. Went trapezoid on me not on flat surface. Apiece of wood under one of the legs sorted it.
S.
March 11, 2008 at 10:12 pm #245538M1
I did notice that one off these TD had the back two feet missing, it may have buckled the frame, both off these machines have had little use & are under a year old.
March 11, 2008 at 10:51 pm #245539helo_75
Participantwell documented problem, and the only real cure is a new modified drum, part number 1703662
no more washers and stuff, put drum in, walk waway, job done
but then theres the costing of it………
March 11, 2008 at 11:21 pm #245540bobokines
Participanthelo_75 wrote: the only real cure is a new modified drum, part number 1703662
Can you tell me what is in the kit please
bob
March 11, 2008 at 11:26 pm #245541iadom
ModeratorRe: Indesit TD Model IS60V (vented dryer)
It really is just a drum & shaft Bob, plus a huge template in case you need to refit the paddles on the sensor type.
Basically the same drum, just rounded off at the back. Less than £29.00 ex vat from Masterpart, that will be about £75.00 from Connect then. 😉
March 11, 2008 at 11:34 pm #245542johnnyj
Its only £27.93 plus vat from connect Jim, i’ve got one or two spare myself.
March 11, 2008 at 11:36 pm #245543iadom
They must be making it up on the bearing tool kit then. 😆
August 2, 2010 at 4:32 pm #245544Phidom
I went to fit a new rear shaft on one of these and found it did not have the screw on shaft plate but a bigger plate that’s riveted on. I ended up drilling out the remains of the old shaft and enlarging the 3 small holes in the back of the drum to allow the screws some clearance to screw from the inside. Is this normal procedure on these or is there an easier way?
August 2, 2010 at 4:41 pm #245545iadom
As you noticed the holes don’t quite line up if you try to replace the later shaft for the old, riveted one.
I use the exact same method as you. 8)
Four screws in all the ones I have done though.
Officially you are supposed to replace the whole drum. :rolls:
August 2, 2010 at 8:05 pm #245546Phidom
Are you sure? There were 3 in all the shafts I’ve done. 😕
August 2, 2010 at 9:18 pm #245547iadom
DOH, of course there are, I was thinking about something else altogether at the time. 😳
