INDESIT W/D (IWDE126) Error on drying cycle…
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries INDESIT W/D (IWDE126) Error on drying cycle…
  • #87939
    neon_3SP_glow
    Hello, please can someone confirm that the error sequence listed below is in fact F13 relating to a high temperature on the drying cycle/NTC fault?…
    The error is presented as flashing LED’s. LED 5 is the red door lock light, the other four are Green LED’s corresponding to various options.
    LED 1 — LED 2 — LED 3 — LED 4 — LED 5
    ON——–ON——–OFF———ON———ON
    The machine intermittenly faults during the drying cycle.
    I suspect either a reduced airflow though the filter or a faulty NTC.
    Many thanks.
    #436522
    neon_3SP_glow
    Re: INDESIT W/D (IWDE126) Error on drying cycle…
    SOLVED…
    The error code was indeed relating to a drying over heat fault.
    Where the plasic chamber attatches to the rear of the drum there is a plastic filter that was completely bocked with wet fluff/lint and gunge. Removing the plastic chamber and cleaning this filter solved the fault. I did also replace the NTC, but the restricted airflow in this area was obviously causing the problem.
    Cheers.
