Indesit w/d WIDL126S
  • #51066
    Allsorts
    This machine is filling with water, tumbling once, then stopping and going no further… Just the Wash light and the on/off light lit – no flashing lights. This machine has a cold-wash setting and just to erradicate a possible heater problem I have tried it on the cold-wash setting.
    History:
    Had a problem with this machine a month back… The machine had a faulty thermistor (running at 78k ohms) and board, so I got a brand new thermistor and a reworked board from EMW .. That sorted the problem until now (one month later)
    #306782
    Re: Indesit w/d WIDL126S
    Your best bet is to call EMW Monday am and explain situation. They will usually send out another board if they’ve got a few in stock, to save you having to go back twice.
    Mike.
    #306783
    aqualectric
    Did you tighten ALL the connections when you fitted the PCB? I had the same problem with a Servis board a while back. The machine kept boiling up even with a new thermistor. Turned out to be loose edge connectors……. :rolls: They have to be extremely tight.
    HTH,
    Steve.
    #306784
    Allsorts
    aqualectric wrote:Did you tighten ALL the connections when you fitted the PCB?
    Yes, the machine worked perfect for about a month, but now like I said, it just sits there after its first tumble, as if it is waiting for the water to heat
