Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit W/D WIDL126UK Clothes come out wet and hot.
- This topic has 5 replies, 2 voices, and was last updated 15 years, 5 months ago by
Twoten.
October 21, 2010 at 9:54 pm #58201
Twoten
ParticipantCustomer complaining that when this machine has finished a wash the machine has overheated shrinking the clothes, the machine fails to spin and the clothes come out hot and wet.
They are sure the machine is not set to tumble dry, they say the machine doesn’t flash any error codes.
The inlet hoses are the correct way round, the machine spins and drains when tested. No earth faults found.
It sounded as if the machine was going into the dry cycle and not condensing. The condenser is clean and getting the water supply and the fan is working OK.
I’m running out of ideas where else to look!
Any ideas on this one would be appreciated.
October 23, 2010 at 9:26 am #333705Twoten
ParticipantRe: Indesit W/D WIDL126UK Clothes come out wet and hot.
Update to above.
Returned to machine and have confirmed at the end of a wash the machine goes into the tumble dry although the dial is set to the off position. I have checked the control knob is not offset.
I can only assume this has to be either the fascia PCB or the main control PCB.
Has anyone found this problem before or have any idea which PCB it’s likely to be?
October 23, 2010 at 1:10 pm #333706iadom
ModeratorRe: Indesit W/D WIDL126UK Clothes come out wet and hot.
Sometimes the dryer will run when not selected if the small wiring plug on the dryer control has come adrift or is not properly connected.
October 23, 2010 at 1:59 pm #333707Twoten
The connector appeared to be OK, I removed and refitted it but because you have to go thorough a cycle to test didn’t know if it rectified the problem or not.
If a loose connector can produce this fault i think it might be worth going back and tightening the connections on the fascia and control PCB and seeing what happens.
October 23, 2010 at 2:04 pm #333708iadom
Sounds like a facia PCB problem, might be case of sending both PCB’s to EMW to test.
October 23, 2010 at 2:35 pm #333709Twoten
If I couldn’t get any suggestions here a call to EMW on Monday was next on the agenda.
Thanks.
