Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit W/drier WD11UK…Clicking Through on Timer
- This topic has 6 replies, 3 voices, and was last updated 20 years, 2 months ago by
laurenceuk.
February 9, 2006 at 11:21 am #15510
laurenceuk
ParticipantHi,
Fills ok, empties ok, motor good, heater ok, stat 30k/ohms approx at ambient.
On selecting wash or rinse this machine will fill then stop and the motor will turn slightly and stop. After a few seconds relay activity is heard then macine goes to pump out and the timer then clicks around continuously. If a spin only is selected it will carry out this function ok.
Am I to suspect the control pcb?
Thanks,
Laurence
February 9, 2006 at 11:30 am #163873iadom
ModeratorRe: Indesit W/drier WD11UK…Clicking Through on Timer
Is the indicator light flashing when the selector knob starts to rotate, it should be flashing an error ocde.
February 9, 2006 at 11:38 am #163874laurenceuk
ParticipantRe: Indesit W/drier WD11UK…Clicking Through on Timer
Hi Iadom,
Yes I think it did…was`nt concentrating on the light.
How is this interpreted as a code so I can re-check it.
Thanks,
Laurence
February 9, 2006 at 12:12 pm #163875Dave_Conway
In the known error codes Laurence, it’s the usual Indesit Evo controls list.
Indesit Evolution Range Error Codes also refers to the number of flashes on the non-lcd type
F01 Short Circuit-Motor Triac
F02 Motor jammed or tachogenerator detached
F03 Temp probe o/c or s/c
F04 Pressure switch jammed on reset
F05 Pressure switch jammed on trip
F06 Programme selector management error
F07 Heater relay stuck
F08 Heater relay cannott be activated
F09 Incompatable eeprom
F10 Pressure switch not sensing correctly
F11 Pump cannot be be activated.
F12 LCD Display module and main module not communicating correctly.Dave
February 10, 2006 at 8:58 am #163876laurenceuk
Thanks Dave
February 10, 2006 at 4:56 pm #163877laurenceuk
The machine is giving ten flashes so I assume it relates to the pressure switch. Funny enough it crossed my mind momentarily when I tested it as it felt spongy on changeover and not at all posative.
Partfinder gives three options 🙁 .
Machine serial number is 312193362 would I be correct in assuming it is pt no. C00110327.
New line with Connect and no stock.
Can anyone supply me with one from their stock if you have any.
Laurence
February 10, 2006 at 6:05 pm #163878Dave_Conway
Yes, that’s the correct part number Laurence 🙂
