indesit w101 tub bearings
  • #9589
    flash
    hi guys
    I was woundering if anybody can help. I went to a job on friday
    it was an indesit 103uk the machine is in need of tub bearings . 113 has got a metal tub but 103 has got a plastic tub. but after lifting the lid I just cant find any way to split the tub. so I was woundering if you can change the bearings or do you have to change the whole tub 8)
    #134753
    Dave_Conway
    Re: indesit w101 tub bearings
    It depends which version it is, but if it’s not obvious that the drum seperates then it won’t flash 🙁
    Complete inner and outer required to repair on these, I wouldn’t bother pricing it 😉
    Another brilliant piece of Merloni design work !
    #134754
    Partfinder only shows complete drum for W103UK/B at £120 + vat. 😥
    #134755
    flash
    hi guys Thanks for that I thought that might be the case ,and I will deliver the bad news in the morning and suggest a replacement washer 😥
