Indesit w103 F8 fault
  • #11964
    Sparkcymru
    Indesit w103 . Starts to fill then empties and timer round and round with 8 flashes. Replaced heater first then changed the board but problem still occurs. It is intermittant though not on every wash. Any ideas where to look next?
    #147317
    Re: Indesit w103 F8 fault
    There’s a couple of clues in “error codes” thread.
    One says relays may stick on new boards- try tapping them.(lotusray?)
    Other says he got 8 flashes on this model and it was a poor fitting thermistor plug on heater.(cornwell40?)
    I would have checked pressure switch/vessel if I’d come across the symptoms you describe.
    #147318
    Sparkcymru
    ok i’ll look at the thermister next and pressure switch etc. Wiring seems ok. It takes about 2-4 goes to get it to fill and run ok without it going wrong and it empties sometimes about two mins after its filled or sometimes during filling. Its a rather inconsistant fault and they are the worst to pin down!
    #147319
    andy2
    Was the replacement board new?
    #147320
    Sparkcymru wrote: it empties sometimes about two mins after its filled or sometimes during filling.
    Are you sure it’s not syphoning?( Check end of drain hose is above fill level.)
    #147321
    Sparkcymru
    Awaiting temp sensor and pressure switch to arrive. Machine is filling up on own when not switched on as well now even with drain hose disconnected so I know its not syphoning. Have ordered cold fill valve as well. Parts are cheap as chips for this machine and I can see why! Will update when i’ve got the parts. At least it still washes once its decided it wants to so there is no huge laundry pile building up.
    #147322
    Sparkcymru
    Ok it turned out to be the pressure switch. Changed that first and problem vanished. Replaced the fill valve too to stop it filling when switched off. Thanks all. What a heap of junk this machine is!
    Steve
