INDESIT W103 WASHING MACHINE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries INDESIT W103 WASHING MACHINE
  • #19154
    TOWAN
    Do not do a lot on Indesit.
    Have got a w103 that when you select a prog will start ok but after around 10-20 sec the selector switch moves round and round.
    Does this no mater what program selected.
    I am thinking that the module is the cause.
    Am i correct!!
    Thanks for any help.
    Dan
    #181928
    Dave_Conway
    Re: INDESIT W103 WASHING MACHINE
    Don’t forget the flashing light then check the codes in the known error code thread Dan 😉
    100’s of posts on this problem on the site 😀
    #181929
    bzz67
    first have you reset the program by swithing off for 1 minute,select zero then switch on until neon has done its little rapid flashing bit.always test motor,heater & thermistor before ordering pcb.try emw for board then if its not that at fault they will only charge you for the test.
    #181930
    pup
    check pump make sure it draing all water out
    #181931
    aqualectric
    Try swapping the pressure switch. Yes; I know it sounds unlikely, but the terminals inside the switch burn and fail even though they seem to still click on / off. It appears to be quite a common fault with these machines.This causes the timer to ‘abort’ 3 or 4 minutes into the cycle. Not necessarily the PCB. 😉
    Hope that helps!!
    Steve.
    #181932
    TOWAN
    thanx for your replys!
    Cheers Dave, forgot the code thread!!
    #181933
    TOWAN
    thanxs again Dave
    8 flashes heater relay fault
    new board fitted all ok!!
