Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit W1035WG blows trip
- This topic has 18 replies, 6 voices, and was last updated 20 years, 5 months ago by
leavemetogetonwithit.
November 4, 2005 at 11:47 am #13047
ParticipantThis machine is in excellent condition for its age, which is why I went to the trouble of replacing the spider/bearing recently 🙄
Now it works fine even on spin but somewhere around no5 on timer (cold wash/rinsing?) when the motor starts up the trip blows. Not every time, it’s intermittent. Now I thought, just like you, that I must not have sealed the stat grommets properly and that I would find a leak. But not so, the thing is watertight checked repeatedly even with a load of towels on spin.Pump is not leaking though it did feel a bit hot but I think that’s normal after running for a while?
I did not have my megger with me 😳 ,and my meter battery gave up just at that moment 👿
Anyway, I took the motor off and had a dekko. Brushes have about a year left on them. The wires to the field coil are insulated with a glass fibre sheath and the blue gunk with which this is impregnated got all over my hands so maybe it’s not doing its job.
I’ll make sure I take my megger when I go back next week. In the meantime has anyone any pointers? And does anyone think they might have a s/h (obsolete) motor for this one. (I forgot to lookat label, but it’s round, 1000 spin, 6 terminals fairly sure, fits easy with one fixed bolt and one sliding,metal drum)
Mike.November 4, 2005 at 2:07 pm #152823Martin
ParticipantRe: Indesit W1035WG blows trip
Mike,
I think you may have answered your own question here 😉
leavemetogetonwithit wrote: I did not have my megger with me
Take that along with you next week and you’ll soon suss it out 🙂
November 4, 2005 at 10:46 pm #152824bobokines
How can you do a day’s work without a meggar?
Sorry Mike, but Martin’s right, there’s no guesswork here, you just can’t assume that a machine is safe to plug in without a meggar test!
Bob
November 5, 2005 at 8:39 pm #152825leavemetogetonwithit
I’m gonna be going back Wednesday. It’ll be interesting to see what the meter(with new battery) and megger each show. I’m hoping it’s just gonna be carbon build up round the motor and that it’ll respond to a good clean up.
Mike.November 5, 2005 at 8:51 pm #152826bobokines
If you have just changed the bearings and drum support, did you inspect the heater for damage when you had it out?
Bob
November 5, 2005 at 9:10 pm #152827leavemetogetonwithit
Yup.
Appreciate the thought though.
It heats up no problem.
Mike.November 5, 2005 at 9:44 pm #152828bobokines
If the heater has a low insulation resistance it will still heat up. If the motor has a low insulation resistance it will still rotate, but if you add the two low insulation resistances together it may be enough to trip an RCD.
Your test meter will sort it out for sure.
Bob
November 5, 2005 at 11:51 pm #152829Penguin45
Megger the heater with water in and after it’s been heating for a few minutes.
November 6, 2005 at 11:58 am #152830Phidom
I’ve probably got a motor if you need one.
November 7, 2005 at 10:09 pm #152831leavemetogetonwithit
Phidom wrote:I’ve probably got a motor if you need one.
Thanks.I’ve a strong feeling that’s going to be useful.
Mike.November 7, 2005 at 10:16 pm #152832leavemetogetonwithit
Penguin45 wrote:Megger the heater with water in and after it’s been heating for a few minutes.
Thanks for the tip, Chris. We have soft water here and the only times I’ve ever needed to replace a heating element are when it has been grooved due to spider fracture (Hotpoints mainly of course). You lucky devils in hard water areas who get these nice easy little earners replacing heating elements don’t know how lucky you are. 😆
MikeOh hang on aminute. IS the Antarctic ice made with hard water? 😆
November 10, 2005 at 12:14 am #152833leavemetogetonwithit
It was the motor. Showed 300k on multimeter and 150k on megger @500v. Armature as usual. No amount of cleaning caused any change.
I’m in the market for s/h one then.Yellow label reads: Indesit Type 1000 / (a very big) A
washing A 4,0 W 85
spin A 2,0 W 280
I’ll pm Phidom.Mods: Is it OK to post this in “Classified”, too?
Mike.November 10, 2005 at 12:23 am #152834kwatt
KeymasterRe: Indesit W1035WG blows trip
leavemetogetonwithit wrote:Mods: Is it OK to post this in “Classified”, too?
Posted as an advert I have no issue with it.
November 11, 2005 at 2:11 pm #152835leavemetogetonwithit
Phidom’s motor is an Indesco 16P. I don’t think it would fit would it ❓ Anybody remember these things?
As the weekend is approaching, I thought this would be a good moment to try and get this thread up near the top of the list and pester you guys with it so you can all spend hours of your spare time sorting through your garages/attics. Think of it as a break from the infernal PC. And think how nice it’ll be to know where everything is again; for a little while.
While you’re there, don’t forget to look out for that AEG motor I’m after (see Classifieds).
Many thanks in anticipation of your exhaustive efforts. 😉
Mike.November 11, 2005 at 9:46 pm #152836Phidom
See your inbox. I think my motor would fit but it looks like you will need to juggle the plug spades as mine is a later type plug.
