INDESIT W113 problems
  • #8789
    simon26r
    THE TIMER GOES ROUND AOND ROUND AND ROUND.
    the light flashed 8 times slow and when it reset it flashed 3 times fast.
    machine half fills then it pumps out and goes round and round again..
    #130518
    Dragan
    Re: INDESIT W113 problems
    Hi,Simon 😉
    F08:Rasistance Missing or PressureSwitch stuck on Full Found
    Overhaul CN1
    Overhaul Rasistance connection
    Overhaul Pressure Switch connection
    Replace Rasistance
    Replace pressure switch
    Replace card
    Dragan
    #130519
    8 flashes is a Heater/Thermistor fault or Heater Relay on Module at fault 😉
    Don’t take that as the only reason for the Slave Timer skipping merrily though 😉 You should look very carefully at the motor for sure 😉
