INDESIT W123
  • #18253
    kettlefiller
    Hi All,
    Hoping for some help regarding the above.
    The machine seems to be doing all its supposed to….apart from the washing/drum turning.
    Was guessing it could be the brushes, are these easily fitted in this make/model machine?
    Many Thanks.
    #178320
    Re: INDESIT W123
    Brushes, belt, wiring and electronics are all possibilities on these things – check carefully and safely – Power Off.
    The brushes are in plastic holders on the end of the motor – easiest to actually drop the motor out rather than trying to get them from underneath.
    If the brushes have worn out, you will be able to source them through spares@ukwhitegoods.co.uk .
    kettlefiller
    Re: INDESIT W123
    Cheers Penguin 45, not as clear cut as i was hoping, Never is, eh.
    Many Thanks.
