indesit w123
  • #33500
    Owain84
    hey went to a m/c this morning and customer complained of water flooding out. had a look underneath and found problem that screw has fallen out of machine which is now just a hole for water to pore out of. the screw is directly underneath the heater. ne idea what this for and what to do now. customer can’t find screw and i’m guessing its not just an ordinary screw
    Cheers
    Owain
    #238936
    timdowning
    Re: indesit w123
    The screw is to hold the heater bracket in place IIRC.
    #238937
    Owain84
    Re: indesit w123
    ok so can u get that screw or shall i just seal it off with silicone?
    #238938
    Re: indesit w123
    Owain84 wrote:can’t find screw and i’m guessing its not just an ordinary screw
    Now, this W123 you are blessed with trying to fix? Is this the early version with the removable backplate? Or the gem with the stainless one piece drum? Or if you really struck gold, is it the latest one with the all new plastic one-piece drum ensemble? 😈
    With the first one at least you can take out the backplate and refit was after all is the heater securing bollard using another conventional screw, washer and rubber seal. If it’s either of the latter two? Then bung up the hole with steel putty I would. 😉
    #238939
    timdowning
    Re: indesit w123
    Don’t have parts list available, sorry. If you just silicone the hole this may stop the leak but the heater won’t be supported by a bracket. You could try the machine on fast spin with a full load and see if the heater taps up or down.
    (You could try a shorter heater if you cant get screw and bracket.)
    #238940
    Owain84
    Re: indesit w123
    its the one piece stainless steel drum. Great stuff!
    when i shone a light by the heater. i couldn’t see a bracket all i could see was a hole. the heater looks quite sturdy to be honest so i think i will try the putty
    #238941
    Re: indesit w123
    The screw secures a “mushroom” to stabilise the heater. You can fiddle it all back together by removing the sump hose.
