Re: Indesit W123 Error Code Three?
An error code is represented by a repetative pattern of flashing lights from the start lamp whilst the dial clunks round.. Normally, three quick flashes indicates that the programme has been accepted and things should proceed…
I suspect that you are describing a motor fault – select programme, door locks, nothing happens. In this case, go straight for the drive motor and check the carbon brush gear.
Article on carbon brush drive motors can be found HERE.
A selection of Indesit carbons (one of which will fit your machine) can be found HERE.
Power off if you intend to investigate this yourself.
Whilst it’s far from the finest washer ever built, carbon brush wear is a maintentance job and should at least be investigated.
