Indesit W123 error codes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit W123 error codes
  • #25120
    briwy
    Sorry to be thick but where do I read the error codes.
    The book that came with the machine does not mention these at all.
    The machine is as above Type LB2000C
    Problem is that the machine wont run any programs at all.
    Simply fills with water and pumps it out with the dial rotating all the time.
    I read the sticky that this is a well documented fault but a search doesnt seem to bring upa specific cause/fault/solution.
    Any help much appreciated
    #204581
    Re: Indesit W123 error codes
    If you have the red flashing light, please count the pattern – ie 1-2-3-4-pause-repeat. This is the code.
    briwy
    Thanks Penguin
    Ill get counting
    #204583
    briwy
    Penguin its sorted.
    Error code 3 came up and I found another post with the same problem.
    It suggested checking the connections from the temp sender to the module.
    Lo and behold a waire had broken inside one of the plastic spade covers.
    New spade terminal crimped on and away it went.
    Thanks very much for the help
    Regards
    Brian
    #204584
    Nice one – result!
