I have a Indesit W123 Washer that the programmer continually clicks and Lamp flashes 5 times before pause. Any idea what fault could be I recon a pump problem but could not find anthing specific to the W123 and 5 flashes on this site.
Five flashes relate to the pressure switch ( water level controller) although faults on the contol module and its connections can also give this error, if the machine appears to empty correctly then it may be time to try repairs@
I believe this is usually caused by a blockage in the air pressure chamber or a faulty Pressure stat, although it has been known to be caused by a blocked pump also.
If you have already checked your pump and filter then I suggest you try
Repairs@ to find an engineer locally.
