Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit W123 not taking in water
- This topic has 13 replies, 6 voices, and was last updated 18 years, 3 months ago by
phil_b.
January 9, 2008 at 1:55 pm #33538
phil_b
ParticipantHi there, wondering if anyone can assist with why my washing machine has stopped taking in water. It stopped mid cycle prior to the rinse and although I have reset the machine and checked filters etc whenever I start a new wash nothing happens despite it going through the usual pattern of 2 long flashes followed by 3 short flashes then a continuos light.
Without being an expert I would guess the pump is no longer working. If that is right does anyone know how much it would cost to replace it?
January 9, 2008 at 5:17 pm #239063iadom
ModeratorRe: Indesit W123 not taking in water
Does it empty when set to spin?
January 9, 2008 at 8:07 pm #239064phil_b
ParticipantRe: Indesit W123 not taking in water
Hi there, thanks for replying. Just realised that it doesn’t do anything on any setting. No matter where I set the cycle to start the red light stays on solidly and the machine does nowt 🙁
January 9, 2008 at 10:21 pm #239065iadom
If the door locks then it may well be a faulty pump, the only way forward is to get the pump checked out electrically, with the mains plug removed of course, then its a matter of going through each component, then you may finally decide that the module is faulty ( it is well over 5o{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time) then if you have any sense you realise the machine is of sub standard quality and hopefully resolve to spend a little bit more and buy something decent next time.
Most faults should cause the control knob to start clicking round and the mains light flashing, no fault indicators often mean the motor or brushes are faulty.
January 10, 2008 at 12:36 pm #239066phil_b
Fair shout but I though it was a good one at the time as my sister has had teh same indesit machine for nearly 20 years ! Any reccomendations on a new machine?
January 10, 2008 at 4:43 pm #239067iadom
January 10, 2008 at 4:44 pm #239068helo_75
Participantif the door is locked and it wont start, its probably the motor brushes
worth a try…
January 10, 2008 at 8:12 pm #239069phil_b
Thanks for all the replies guys, much appeciated. Will try new brushes and failing that it looks like a new machine may be in order. Regards, Phil
January 16, 2008 at 10:16 pm #239070phil_b
Got the brushes from UK whitegoods website and have fitted them without too much trouble. Washing machine is working again 😀 although it is a bit noiser then before during the cycle – is this just the brushes ‘settling in’?
January 17, 2008 at 12:19 am #239071Penguin45
If it’s a whizzy noise not unlike Mr McHenry’s tricycle from the Magic Roundabout, it’s the brushes settling and nothing to worry about.
January 17, 2008 at 1:07 pm #239072phil_b
That’s exactly the noise 😀 . Thanks for all the help.
January 18, 2008 at 10:51 pm #239073garn
indesit w133 & w143
try filler valve solanoids commen fault on w123 & w143 also the same on the ariston margarita looks like timer problems can be valve sometimes can itermitantJanuary 18, 2008 at 11:59 pm #239074hotpnt
garn, what???
January 19, 2008 at 1:14 am #239075Penguin45
OP has resolved the issue with his appliance, this thread is completed.
Penguin45,
Moderator. -
