Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit W123 stuck in cycle
- This topic has 11 replies, 4 voices, and was last updated 15 years, 10 months ago by
PeteW1959.
June 2, 2010 at 5:37 pm #54966
PeteW1959
ParticipantHi,
I have a W123 that sticks part way through a cycle. It doesn’t always stop in the same place, and advancing the dial manually just causes it to continuously click round.
The only way to clear it is to unplug the power for 20 minutes, advance the dial manually and power up again. However it will then stick further on. The fault happens every time.
peteJune 3, 2010 at 5:42 pm #321535iadom
ModeratorRe: Indesit W123 stuck in cycle
Is it sticking during the wash, rinse or spin?
What is it doing when it sticks, can you hear anything like the water filling or draining?
June 3, 2010 at 5:58 pm #321536PeteW1959
ParticipantRe: Indesit W123 stuck in cycle
It can stick almost anywhere, but usually during wash or rinse.
There is no particular action, it carries on with whatever it was doing e.g. rotaing drum, or maybe emptying but sometimes it is doing absolutely nothing.
There are no error flashes either.
June 3, 2010 at 6:26 pm #321537iadom
Worth checking the grey water outlet pipe to make sure the machine is not syphoning during rinses.
If the grey pipe is stuffed right down inside a standpipe or the standpipe has fallen over that could cause this problem.
If the grey pipe does go into a standpipe it should go down no more than five or six inches into the standpipe.
If it is connected to the sink waste pipe then it is less likely.
June 4, 2010 at 7:11 am #321538PeteW1959
It is connected to the sink waste pipe, through a proper connection on the trap. There are no kinks or blockages either.
June 4, 2010 at 8:58 am #321539iadom
Hmm, it is pointing towards either the small timer unit or a main board fault.
If you have had a look around the forums you will no doubt have realised that Indesit machines and their controls have a very poor reputation for reliability.
If you have access to a megger or multimeter you could test all of the components individually and also check the motor brushes.
I am assuming you have already checked the pump filter etc.
June 4, 2010 at 8:33 pm #321540PeteW1959
It has finally managed to produce an error code, so hopefully that will point to the problem.
Error code is 7. I’ve searched the forum but it would seem that no one else has had the same code!
June 4, 2010 at 9:11 pm #321541iadom
Sadly seven flashes indicates a heater relay fault, or in other words the woeful PCB is at fault. 😥
May 10, 2011 at 7:38 pm #321542actsafe
Hi I have exactly the same fault, which developed in the same way. I ticked off all the other checks in your posts.
Is it the timer or the module that I require as a spare part? (heres hoping its the cheaper timer)
I can only see the timer unit for sale on the spare parts section? – here.
http://shop.ukwhitegoods.co.uk/Washing+ … ector.html
Is the module still available?
model number indesit W123UK BG
serial number 210251732
I can get the part number off the module or timer if required.
Many thanks in advance
AndrewMay 10, 2011 at 7:47 pm #321543kwatt
KeymasterRe: Indesit W123 stuck in cycle
Yeah it is but it’s one of those you have to buy the module and then the EEPROM for it as well and, for that lot, you can kiss goodbye to the best part of £100 if not a little more.
I struggle to recommend spending that much on an Indesit, even new. 😉
May 10, 2011 at 8:07 pm #321544actsafe
OK thanks.
Seen module for £120 which is almost half what my wife paid for it 8 years ago (probably therefore have had moneys worth out of it).
Also found someone (QER) who will repair module for £43 plus P&P, with 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} success rate claimed.
This seems worth a shot given the price of a new Bosch or ISE.
Any thoughts on PCB repairs welcome.
Thanks Again
AndrewMay 10, 2011 at 8:57 pm #321545iadom
kwatt wrote:Yeah it is but it’s one of those you have to buy the module and then the EEPROM for it as well and, for that lot, you can kiss goodbye to the best part of £100 if not a little more.
PCB list £100, smart card £15, card reader £100. :rolls:
