Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › indesit w123 uk bg
- This topic has 7 replies, 5 voices, and was last updated 15 years, 1 month ago by
slyp98.
February 11, 2011 at 7:10 pm #60979
slyp98
Participanti went to this washer today , s/n 309041046 91268710002, constantly taking in water , the solenoids are always energised even when the m/c is turned off , select a program and start and it pumps out and fills at the same time , and when the pump stops it just keeps filling and filling , i saw the red led flash 2 times slowly and then 3 times quickly and then it just keeps flashing slowly just when it is turned on no program selected , i checked brushes and armature cleaned them and the ntc and heater element 63.4 ohms from element and 3.4 million ohms from ntc anyone have any diagnostic info thanks
February 11, 2011 at 7:28 pm #344423neilsukwg
ParticipantRe: indesit w123 uk bg
Had same problem with a Bush washing machine this week.
can only be pcb i would think
EMW should sort you out with a refurbished board or slightly slower you can send your board in for test and repair.
February 11, 2011 at 7:39 pm #344424slyp98
do you have an email address for them and approx cost to repair one cheers
February 11, 2011 at 7:52 pm #344425suedehead1
they should have them in stock and will send you one for about £40
and if its not that you send it back for a handling charge of about £6,
if it works you send them the old board.
call them on 01159652118
its definately the pcb.February 11, 2011 at 7:56 pm #344426Allsorts
Trace the supply wires to the valve that is letting water in… See if it is being energised by a short.
February 11, 2011 at 9:31 pm #344427slyp98
they’re both energised , the wires are heading back down the r/h front past the door interlock, i see the control board down there near the base !
February 11, 2011 at 11:08 pm #344428iadom
ModeratorRe: indesit w123 uk bg
Filling all the time regardless of programme is a common PCB fault on this rubbish.
February 12, 2011 at 5:55 pm #344429slyp98
i contacted customer and advised on cost of repair and she is going to buy a new appliance as it is 6 yrs old,
thanks to all who gave input -
