Indesit W123 UKBG
  • #15421
    clivejameson
    This machine has a motor support leg at the rear of the motor, bolts to the tub and fits with a bush into the motor leg….does anyone have the part number for it please? (bush not required, just the support)
    #163531
    Re: Indesit W123 UKBG
    Need exact serial number, different motors,drums and mountings.
    Also is it a W123UK BG/M or BG/P ?
    Partfinder lists W123UK (BG) but comes up with ‘No Parts Listed’ ❓
    #163532
    clivejameson
    No other letters after the model number…..
    serial 210241150
    #163533
    Dave_Conway
    The M and P refer to metal or plastic outer tank 🙂
    Which was it Clive, I’ll try and work it our from there ?
    #163534
    clivejameson
    thanks Dave….its a metal tub
    #163535
    Dave_Conway
    Diagram on the way, I think it’s position 36 ?
    If it is it’s part number C00050187
    #163536
    clivejameson
    It doesn’t seem to appear on that drawing Dave, the supports shown relate to the front of the motor, but the support required is at the back. It bolts to the strut mount on the base of the tub and hangs down to the motor rear leg RHS viewed from the front of the machine, locating with a rubber bush into the motor leg.
    #163537
    Dave_Conway
    Ah, is this the one with the curved bracket thing that’s bolted to the bottom of the drum then the motor bolts to that ?
    C00066074 = “cradle set outer” if it is, I hope that contains the part you need as well, if not I’m goosed on this one.
    #163538
    Is it number 37. C00090124 motor bolt ?
    #163539
    clivejameson
    Dave_Conway wrote:Ah, is this the one with the curved bracket thing that’s bolted to the bottom of the drum then the motor bolts to that ?
    Yes thats the one!….its not the pulley end bracket (39) but this sounds like it?(no bolt fixing, the motor just hangs on a lug with bush on the end of the bracket)
    I’ll give indimerlotpoint another call and see what they say this time.
    Cheers guys
    #163540
    If I enter that in W123 it comes up as ‘Not Found’ it is in the W133 parts list though, doesn’t look much like a support leg to me. ❓
    Might be time for the trusty digital camera. 😉
    #163541
    Dave_Conway
    Just put the part number in to Partfinder for future ref, you don’t need to enter anything else 🙂
    I often do that, it just didn’t look like anything on the W123’s that I have seen. 😉
    #163542
    Dave_Conway
    You and your quotes/edits eh ? 😆
    #163543
    clivejameson
    Just a follow up FYI….I ordered the cradle set but it looked nothing like the mountings on the machine….I managed to get a friend to TIG weld it in the end….proper job!
    It is yet another example of a manufacturer banging out machines at all costs without the careful back-up of technical information and spares supply 😕
