Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit w123 washer – smoking
- This topic has 7 replies, 7 voices, and was last updated 18 years, 11 months ago by
mjw1208.
April 25, 2007 at 12:30 pm #26874
mjw1208
ParticipantGot a customer with a Indesit washer W123 says she was using a wash program and smoke started pouring out from front of machine and she promptly switched off unit, been this morning and drained out machine and then checked for any obvious smoke effects tried machine on several programms and all seems ok . No trace of arcing to timer control or module contacts is there any other things i need to check ,have recently checked pump and unblocked as she had parts of a credit card stuck in it . Any help or suggestions on this fault ??
April 25, 2007 at 2:46 pm #211713hotpnt
ParticipantRe: Indesit w123 washer – smoking
could be something got pushed against seal on spin, (overloaded?), often leads to ‘smoke’ calls
April 25, 2007 at 7:06 pm #211714suedehead1
i assume you have checked for play in the drum, faulty bearings or a broken spider could allow the drum to rub on the door seal.
April 25, 2007 at 7:08 pm #211715clivejameson
mjw1208 wrote:have recently checked pump and unblocked as she had parts of a credit card stuck in it .
Parts of?…..so where’s the rest of it? 😉
April 27, 2007 at 1:42 pm #211716mjw1208
have had the machine on test for nearly 2 full days and no smoke or fire , possibly been overloaded but still the customer wants to make an insurance claim as they have old for new cover !!!
April 30, 2007 at 4:28 pm #211717MickGeorge
Not sure if your m/c has s/s tub but had one of these with a small crack at the suspension spot weld and caused a slight leak down on motor or motor block (think it was the block)… anyway caused motor to smoke but only leaked on load when m/c was moving about.. Might be worth a quick inspect but you probly checked already
Mick
April 30, 2007 at 6:02 pm #211718admin
KeymasterOr perhaps she used one high temperature (more than 60’s) and sees vapors…
I’ve had only one time: noise reduction filter blown in such way, if I wouldn’t checked supplementary I wouldn’t find the problem.PS. On burning smoke cases smell persist inside machine long time.
April 30, 2007 at 7:58 pm #211719JOHN CLARKE
If she used a 90c wash, by the time the machine gets to spin the motor is quite hot, when it spins and air is blown through it there can be quite a burning smell. Not sure about smoke though, shes not just after a new machine maybe.
